How do I make a current source using transistor and zener diode?
Status
Not open for further replies.
skymin0202
Joined Feb 11, 2019
15
I have a load that has varying resistance with external pressure. In order to measure the change, I am trying to measure the voltage on the load, when constant current is applied. And the circuit in the attachment is known to supply constant current using a transistor and a zener diode. But I have no idea what resistor/ transistor/ diode I need. I do not know if the circuit will burn them out.
The current on the load has to be approximately 6 mA, I think. And the supply voltage will be 5V. If needed, the transistor and zener diode I purchased are KTC3198, and 1N5231B-5.1V, respectively. The Vz (breakdown voltage of zener diode) will be 3.3V. Please comment, if any further information needed
dl324
Joined Mar 30, 2015
18,472
Why did you start a new thread?
I'd operate the zener at Izt, that's the current where Vz is valid. Data from OnSemi datasheet:
For the zener you're now going to use, that would be 20mA.
\( \small R = \frac{V}{I} = \frac{10V-3.3V}{20mA}=335\Omega \)
The closest 5% value is 330 ohms.
If your supply voltage is stable, you could use a lower current.
Status
