How do I identify the correct power source for a circuit?
cncmaker
Joined Nov 20, 2019
2
I've got hold of a Bluetooth controller module. But I do not know whether is should be supplied with A/C or D/C voltage (and if DC then what voltage). Is there a way to go about determining this?
I've got a picture of the PCB. 2 wires are the supply and the 3rd wire is a switched live activated when bluetooth remote control is pressed.
SLK001
Joined Nov 29, 2011
1,549
Well, you start by getting datasheets of the devices on your board. The N52632 is a Bluetooth controller that has a DC input voltage range of 1.7 to 3.6V. The SOT89 device looks like an on-board voltage regulator, so your input at the connector has to be high enough to allow the regulator to regulate - probably 5V or so.
So, download the datasheet for the N52832, find the pinout to locate the VCC lines, then hookup a variable DC supply to the DC input line and, while monitoring the DC VCC voltage on the BT chip, slowly increase the input voltage until the VCC pin reaches a plateau. My guess is that your input DC voltage will be either 3.3V or 5V.
Dodgydave
Joined Jun 22, 2012
11,307
The N52832 chip has a voltage supply of 3.6 to 3.9V, the regulator B521r is probably a 3.6V so you can input 5V DC supply
