I can make my own PCB's. I would prefer through hole mount as easy for learningIt's far better if you use a power adapter, since I'm under the impression that you intend to use your device continuously. Also, efficiency would cease to be a concern and the design would be far simpler.
Question #2, how do you intend to mount the components? Can you make your own PCB's?
I can get some components locally. The rest I will import from mantech or RS in south africa. If I have to import them then I wait a couple of daysQuestion #3, how do you plan to buy the components?
Thank you very muchOk then. What you're asking for is so easy that I'll be more than glad to help you design it. Give me a few hours and I'll post the basic diagram here.
Why you not choose LM2901 or LM339?Ok Rod, here's a preliminary diagram.
Your sensor's output is connected to a series of comparators connected in parallel. The comparators will pull their outputs down when their positive inputs are greater than their negative inputs. Te resistors and trimpots have been configured as voltage dividers to give a maximum adjustable input voltage of 3.3V to the negative inputs of the comparators. This is because that's the maximum output voltage of your sensor. By adjusting each trimpot, you can set the comparator's trigger point to any value that you want.
Remember that the comparators have inverted outputs, that is, their outputs will go low (0V) when they're activated, and will stay high (+5V) when they're disactivated.
For instance, if you want the comparator to pull their outputs down when your sensor's voltage is 1.65V, then you adjust the trimpot to 25K.
Good point Scott. Yes, those comparators are compatible with Rod's application too. Both chips that you mention are quad comparators, so maybe less components will be needed for the TS's project.Why you not choose LM2901 or LM339?
My previous previous boss given me over 50 pcs LM324 4 op amps, so I like to use it to replace the comparator ...Good point Scott. Yes, those comparators are compatible with Rod's application too. Both chips that you mention are quad comparators, so maybe less components will be needed for the TS's project.
If you connect 5 resistors in series, say 10k ohm each, and connect the string between VCC and ground, you will create a voltage divider to use as references to each of your comparators. Take the voltage from the junctions of each resistor and connect to your conparators. The voltages will be .66V at the top of the resistor connected to ground, and +.66V for each up the ladder. The total current will be 3.3V/50kohms = 66uA. You'll need comparators with input bias currents in the order of a 1-2 uA max.I have no idea where to begin
Yeah, that would be the simplest and easiest of arrangements. But the circuit would lose its capability of being adjusted on the spot... I don't know how important that would be for the user, though.If you connect 5 resistors in series, say 10k ohm each, and connect the string between VCC and ground, you will create a voltage divider to use as references to each of your comparators. Take the voltage from the junctions of each resistor and connect to your conparators. The voltages will be .66V at the top of the resistor connected to ground, and +.66V for each up the ladder. The total current will be 3.3V/50kohms = 66uA. You'll need comparators with input bias currents in the order of a 1-2 uA max.
Thank you for this. I will try and by the various components today. Being able to adjust the settings, makes so much sense. This will allow me to monitor and switch under different conditions.Ok Rod, here's a preliminary diagram.
And btw, you can add more stages if you like, you don't have to settle for just 5. If you get quad comparator chips, with just a couple of chips you'd be able to set 8 divisions.Thank you for this. I will try and by the various components today. Being able to adjust the settings, makes so much sense. This will allow me to monitor and switch under different conditions.
I am wanting to switch mosfets. Which in turn will switch in a fan or a humidifier. I will also have a 5 input gsm module that will notify me when a condition is active.And btw, you can add more stages if you like, you don't have to settle for just 5. If you get quad comparator chips, with just a couple of chips you'd be able to set 8 divisions.
Another question, what do you intend to switch with the outputs? Relays, electrovalves? of what voltage and capacities?
I will print out the circuit then go through it and no doubt have a string of questionsAnd remember to change the value of R2 through R6 to 27K !
EDIT: eek!the LED in the circuit I posted is backwards!
Of what voltage will your fan or humidifiers be?I am wanting to switch mosfets. Which in turn will switch in a fan or a humidifier. I will also have a 5 input gsm module that will notify me when a condition is active.
