How Do I Find The Voc using mesh current method?
WBahn
Joined Mar 31, 2012
33,324
Walk along any path from A to B and determine Vab (or Vba, depending on how Voc is defined, which isn't specified).
WBahn
Joined Mar 31, 2012
33,324
Voc is voltage across open circuit
That isn't enough. Voltages and currents have both location AND polarity. Is Voc the voltage at 'a' relative to 'b' (also known as Vab) or is it the voltage at 'b' relative to 'a' (also known as Vba). These are NOT the same thing -- the difference is extremely significant. Connect your car battery backwards and you will quickly discover this to be the case.
