How do I design an active BJT fliter?
raedshaher8
Joined Dec 22, 2022
30
I have to design a low pass filter using a BJT. I looked everywhere but can't find any proper information. The filter must have a gain of Av=10 with a low cutoff frequency of 10.6kHz. I can design a class a bjt amp with the required gain and I also designed the low pass filter. But I have no clue how to make them into one circuit. Any help is appreciated.
38,818
Make it in two stages.
One stage can have the gain of 10.
The other stage is the low-pass filter .
One stage drives the other stage in series.
What is the required filter roll-off characteristics (number of poles, etc.)?
raedshaher8
Joined Dec 22, 2022
30
When you say two stages you mean two sperate BJTs right?
And there isn't really a requirement for roll-off characteristics. I'm thinking just 1 pole should be enough.
