No problems. If when you have derived your expression if want to post it we can check it for you.ok thanks alot guys! )
Correct, the 1-1-0-1 row is missing.Step 1. Your table has 15 rows instead of 16
The simplification process will eliminate these conditions, for example:Step 2. Adjacent rows may imply a simpler expression. Example, the last two rows reveal that if C=D=S=1, then T is a don't care because the function is a 1 regardless of the value.
by Robert Keim
