How change 12dc/220ac inverter to 48dc/220
Papabravo
Joined Feb 24, 2006
22,115
I have three 12dc/220ac. inverter i need to change input volatge to 48 .How can I do that please help me.
What makes you think it is even possible with the chips in the design you have?
You'll be far happier with a new inverter. Their design and construction is not a task suited for amateurs.
Papabravo
Joined Feb 24, 2006
22,115
The inverter I have is 1500w .so what kind of transformer i need.
That all depends on the design of the inverter. Do you know the turns ratio for the existing part?
To raise the input voltage you need to reduce the number of turns on the secondary by about a factor of 4. Reducing the number of turns is easier than increasing the number of turns on an existing core.
AlbertHall
Joined Jun 4, 2014
12,657
Unless something else is changed (frequency?) that is likely to lead to saturation as the primary now has four times its designed the voltage across it.
Papabravo
Joined Feb 24, 2006
22,115
I never said it was a good idea, I was just trying to point out the difficulties of re-purposing a component without much in the way of knowledge about what you were doing. You point is clearly a killer, especially if you have no way to measure the result of modifying the transformer.
DickCappels
Joined Aug 21, 2008
10,661
Have you considered whether you can find a suitable buck converter to step down the 48 volts to 12 volts? Sounds like your converter would need to supply about 150 amps(!).
Mohmmadthapet
Joined Jul 30, 2017
Unfortunately there is no high current converter in local market in my country so please help me to how I can make 48 dc to 12 dc 40 amber converter.
Mohmmadthapet
Joined Jul 30, 2017
I search for 1500w 48dc/220 ac in the market in my country unfortunately I didn't find sach one I want only I found 12dc/220 ac with 1500w .
