Well Yes!Hello there,
Am i missing something here?
I see a 1uf cap from output to ground, (in series with a DC voltage source which does nothing for AC really).
That second 1uf cap has some serious side effects, such as swamping down the output AC voltage level.
The reactance at 1kHz is around 159 Ohms so we will see some serious gain decrease from the DC approximation of 10000/830 (with B infinite). I will take a guess, 159/830 which is a gain of around 0.19 or even lower like around 0.12 or so.
Is that cap really supposed to be there?
Hi,Well Yes!That's a voltmeter on the output you are looking at with one side grounded. I breadboarded this circuit back in post #4, the voltage gain is 10 at 1Khz with no load. Yes there is some loss through the input coupling cap which explains the lower gain I am getting, 10 vs 12.
SG
With a 2N3904 and the components shown in post #1 the base voltage reads 1.54v, collector 1.5 volts.BTW, what are you allowed to assume for the base emitter voltage drop?
I ask because with a beta of 100 the output DC level with be low with Vbe(DC)=0.7 as usual, although not zero.
SG
Only if the emitter was grounded. The voltages given in post #9 are from the actual circuit not a simulation. The circuit as shown is over biased using a 2N3904 but no transistor was listed in the original post. Changing the 15K to a 22K will set the collector voltage to about 6.5 volts providing a much better output.with a Beta of 100 the transistor collector would drop to something like -5v with the bias network shown, and that would be impossible so it would saturate to zero and that would mean zero gain (zero output for any input). To get the output biased to 1/2 Vcc, we'd need a drop of over 1v i think but that's not mandatory. Maybe you were given a Beta too? If it was lower that would explain a lot also.
Hello,Only if the emitter was grounded. The voltages given in post #9 are from the actual circuit not a simulation. The circuit as shown is over biased using a 2N3904 but no transistor was listed in the original post. Changing the 15K to a 22K will set the collector voltage to about 6.5 volts providing a much better output.
SG
Hi again,MrAL I think you are over analyzing this, but here goes.
First of all I didn't start this thread, it's not my circuit posted in #1. I breadboarded the circuit as shown using a 2N3904 transistor because no transistor was listed and posted some voltage readings in #7
The base-emitter voltage is appx .7 volt, same as all NPN transistor give or take a little you know that.
Beta? I don't know from the specs of a 2N3904 could be anywhere from 100 to 400 depending on the circuit parameters.
Can you change the component values? I assume so since the thread is titled " how can this circuit be adjust to achieve gain of 10"
Did I miss anything?
SG
