How can I use diode to measure temperature
KL7AJ
Joined Nov 4, 2008
2,229
Hi ,
I need to measure temperature using diode like 1n4148 , how can I do that ?
Regards ;)
You certainly can...but the trick is calibrating the thing. If you have a GOOD external thermometer, you can run some resistance/temp curves on this. Then you can either use a conversion chart, or develop a log amp sort of readout.
GopherT
Joined Nov 23, 2012
8,009
The voltage readout from the diode is basically linear with temperature, so I don't understand why you think you need a conversion chart or log amp. :confused:
I believe that is needed with the reverse leakage current method of temp with a diode. Way more complicated but supposedly more accurate.
