How can i find the right switch
Henrik Berby
Joined Aug 17, 2015
4
Hi, i am looking to replace a lost switch on my office table, it is an eletrical table using a hydraulig motor to either lower or raise the table height. Problem is, i cant remember how to find the switch or where to buy it, but i know the function.
the wiring going from the control-unit on the table to where the switch was, consists of three wires, Red, Brown and black.
the black and brown wire is supposed to connect individually to the red wire based on what button is pushed or which way the switch is(Black wire makes the table raise and the black makes it lower itself) as drawn on the picture attached. the button or switch needs to have a rest positon where neither of the wires are connected so that the table can stay still. (either springloaded or whatever, it just needs to retract to the resting position )Table Button Scheme.png
Sorry for the bad drawing, i hope you understand what i mean.
30,686
Really, a hydraulic motor to lift a office table, what weight are we talking?
A little more of the mechanics are required! So far a little vague.
Henrik Berby
Joined Aug 17, 2015
4
Well the table is some old office table from kinarps, it can easily lift a fully set up workstation with me sitting on top of the table.
i dont really know much more of it since most of the parts are inside of the metal casing of the foot. th table has a single foot in the middle where it raises or lowers the table by extending as a telescope.
this is what i found out about the control unit:
Producent: Tollo Linear from Sweden
-voltage= 230v AC -Duty cycle= 15% -Customer part no. 830 120 1000(probably insignificant)
-frequency 50hz -Max On-time= 30 sec
-Current 1.6 amps -2005-01-18(guessing its date of manufacturing)
i looked up the kind of switch on the internet and found these two:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_21910_-1
http://www.radioshack.com/spdt-center-off-high-current-mini-toggle-switch/2750325.html
are these fitting, and if you could find one with casing so that i can attach it to the underside of the table, i would appreciate a link to where i can buy it.
BReeves
Joined Nov 24, 2012
410
Tha'ts fine, but it's only rated for 125V.
We do not know what the control voltage to the switch is.
Just listed the first full size switch I ran across for an example, the little switches the TS linked to are cheap and wouldn't hold up very long.
Henrik Berby
Joined Aug 17, 2015
4
i think both are fine, but ill go for BReeves' solution. since the controll wires are so easily available, i would only come to think that they are within SELV/PELV regulations, there is probably no need for more than a 30V DC rating. and from the looks of it, i would say the control voltage is low voltage DC.
thanks for quick answers
Henrik Berby
Joined Aug 17, 2015
4
that is the input voltage, there are resistors and circuits recucing the voltage of the control wires. probably the same concept as a plc
VOLTAGE MEASURED AT ~3.3V
Brownout
Joined Jan 10, 2012
2,390
In that case, the smaller and less expensive switch you first showed should work. I'd get a measure of the current while I had my meter out.
