How can I determine the value of the resistors?
ED Mendes
Joined May 31, 2019
What is your attempt at the answer?
IC=BF*IB
IC/BF=IB
6mA/150= IB
0,04mA = IB
IC+IB=IE
6mA+0,04mA=IE
RE
-12V+1V+1V+1V+VCE+RE*IE=0
-12V+1V+1V+1V+3V+RE*6,04mA=0
RE*6,04mA=6V
RE=6V/6,04mA=993 ohms
I don't know how to calculate the values for R1 and R2
22,535
Determine the voltage at the base with respect to ground.
You don't really need R2 in order to arrive at a solution.
R1 and R2 is a simple voltage divider. There is a infinite number of solutions in creating a voltage divider.
Select the best solution based on some criteria.
