how can i detect a person is in bed/out of bed
bug13
Joined Feb 13, 2012
2,002
Hi guys
As of the title saiys, thanks guys!
I have already look at those sensor mat type solution (two sheets of conductor sandwich a thin sheet of foam), they are too easy to break. I am hoping something I can attach to a bed/frame/legs/etc.. and somehow I can do the detection.
Thoughts??
Thanks guys!!
Some hospital beds are capable of weighing people in the bed. You'd likely need 4 sensors, one for each leg if you go that far.
It would likely be the most reliable.
You could probably get away with two at the head of the bed feet and check the additive weigh distribution on the two feet. Raise the other legs to compensate for no sensor.
Check www.omega.com under load cells.
A non-load cell cheap sensor https://www.sparkfun.com/products/8685.
<$20.00 USD
The evaluation kit from tekscan is pricy.
WBahn
Joined Mar 31, 2012
32,823
Hi guys
Thoughts??
Thanks guys!!
How many legs does the bed have?
The first thing that comes to mind is a small load cell under each leg, but you might get away with a single load cell under just one leg since you aren't trying to weigh the person, just detect that the load has gone up. How will it be monitored? I can imagine that things get set on an empty bed that would be heavy enough to be seen as a person on a fairly frequent basis.
Depending on the frame structure, another possibility might be putting a strain gauge on the bed frame somewhere.
bug13
Joined Feb 13, 2012
2,002
Just a typical 3 legs bed. Strain gauge is another good idea.
WBahn
Joined Mar 31, 2012
32,823
I'm not at all familiar with a typical 3 legs bed. Did you mean 4 legs?
I would imagine that a strain gauge midway along one of the head-foot rails will give a usable signal.
bug13
Joined Feb 13, 2012
2,002
How about an infrared detector? or a microswitch on a lever from centre of the bed to a leg?
How do you plan to detect with infrared? Could be not reliable in my opinion, unless what you are suggesting is different from what I got in mind.
And about the micro switch, are you suggesting a lever from the bottom centre?
MrSoftware
Joined Oct 29, 2013
2,273
The challenge with PIR (infrared) devices is they only detect change. If someone hops in bed then falls asleep (stops moving), you'll see the motion when they arrived, but you won't know if they're still there or not. A load cell is probably the most reliable. I don't know if an FSR would work or not. It would behave similar to a load cell (resistance changes with load) and it's very thin and relatively inexpensive, but I don't think they're as linear as load cells. Something like this, but with a higher rating:
http://www.kr4.us/force-sensitive-resistor-0-5.html
recklessrog
Joined May 23, 2013
985
Infrared as in the way an alarm sensor works, aim it at the bed from a wall etc.
and without seeing the bed I can't say where to put the microswitch lever, but seeing as there must be some deformation of the mattress and whatever it is on, there must be someway to fit one.
recklessrog
Joined May 23, 2013
985
Ive just thought of another cheap way, you can buy a pressure switch mat that goes under carpets used in alarm systems. put one between the mattress and bed base.
ian field
Joined Oct 27, 2012
6,536
Hi guys
Thoughts??
Thanks guys!!
Someone on this forum occasionally posts; "Nurse - they're out of their beds again!!!" - probably just right for this application.
ScottWang
Joined Aug 23, 2012
7,501
Could you show us how is the bed look like?
For the IR sensors then you can put them at two sides of the bed, maybe three pairs.
bug13
Joined Feb 13, 2012
2,002
Not the same one, but could be something like this, also, I properly prefer to have the sensor stay with the bed, not on a wall of a room. Unless, the senor is portable.
