How can I design a dc to ac inverter which will not use a transformer?
BharathiMN
Joined May 22, 2014
1
Hi i have planned to design a dc to ac conveter with 12vDC input and 230VA output, Please guide me how can i design inverter without transformer?
Sensacell
Joined Jun 19, 2012
3,789
That's like asking for an airplane without wings!
A rocket is an airplane without wings: it's terribly inefficient, complex and expensive.
BillB3857
Joined Feb 28, 2009
2,573
So where does the high voltage come from to begin with? 20 car batteries in series, capacitor/diode voltage multiplier, etc, etc? After you get the high voltage, the H-bridge sounds like the best bet to chop it up and reverse the polarity.
BillB3857
Joined Feb 28, 2009
2,573
WOW! I missed the VA tag. Looked at it only as VAC. I guess a dry cell wouldn't quite do it either, would it? Have an appointment to get my eyes checked.
Brevor
Joined Apr 9, 2011
297
The transformer is the most expensive part of a DC to AC inverter, If it were possible to make one without a transformer someone would have already done so. And they would probably be very rich.
BobTPH
Joined Jun 5, 2013
11,666
It is possible to do without a transformer (but you do need an inductor). Make a step up converter to 325VDC then use and H-bridge to invert it to 230VAC. If you can get the boost converter to run in the MHz region, the inductor could be quite a bit smaller and less expensive then a 12V to 230V transformer.
Bob
