How can i convert 19v output supply into 13v
What's the maximum current?How can i convert 19v output supply into 13v
LM2596Off the shelf buck converter module.
Yes. It's an example of horrible connector wire soldering.Is the picture supposed to tell use something?
To answer your question literally: You might be able to change a resistor in the feedback network to make the output 13V instead of 19V.How can i convert 19v output supply into 13v
By changing the resistors on the Lm358 pins 2&3, looks like one half senses Voltage and the other half does current, .How can i convert 19v output supply into 13v
