Hot 9v battery with PC fan (LED integrated)
Jackbenimble
Joined Aug 31, 2015
2
Hi Guys,
I'm getting a really hot 9v battery when connecting to a 12v pc fan. The fan has LED's build in and there's a toggle switch between the battery and fan. I assumed it was pulling too much current from the battery so I tried added a 330ohm resistor, but the fan no longer spun. Any thoughts? Thanks.
-Jack
bertus
Joined Apr 5, 2008
22,983
When you are using a small PP9 battery, it is not made for high currents.
The battery will gat hot due to the high internal resistance.
#12
Leave the resistor out and watch for flames. :D
But seriously, that tiny battery is in a death struggle with the fan. It just isn't big enough.:(
Pay attention. The heat could get unreasonable.
Have you ever put a 9 volt battery in your pocket with some coins? Frightening how hot it gets!
I don't think it will start oozing its guts out, but watch it closely. This is the wrong thing to do to that battery and it won't last very long.
