The board still works to run the incline/decline motor and powers the control panel at the top. It just won't turn the motor to run the treadmill. Big white relay (JQX-105F) does not click. No 12 volts at the coil.
Can anyone give me any insight as to what components to check next, or have had a similar problem and found a solution?
Board mode: JDYF07L REVi
Thank you very much.
