hi
Please help me out for Honeywell Airflow sensor for reading proper date with appropriate Flow value.
i am getting some data which in increasing by blowing sensor means if air is passing air flow value is increasing
but i am unable to measure actual flow rate. i am not able to read proper sequence given in data sheet of sensor....how many byte of data to read...how many bit to discard and when to start reading.
i want help in reading proper data for airflow but am not getting what exactly datasheet explained in it.
i am attaching datasheet snapshot and full datasheet too
https://sensing.honeywell.com/honey...irflow-sensors-technical-note-008210-5-en.pdf
https://sensing.honeywell.com/honey...ow-10-slpm-300-slpm-datasheet-008268-5-en.pdf
Thank YOu
Thank YOu
