thank you KISSPPE for the uninitiated (likely for the OP/TS) is Personal Protective Equipment
OP is Original Poster and TS is Thread Starter, one in the same.
Sally
Hi HP,While Ican't- ahem... don't dare speak for @Aleph(0)-- Embarrassingly, I was unaware of that!
But then your kind response underscores a vital point! -- Always, always, always vacuum-treat dielectric materials (including bona fide dielectric oils) prior to incorporation! -- FWIW (Re: solid dielectrics) said treatment may safely be deemed 'complete' at such time as absolute pressure in the VC (vacuum chamber) containing said materials remains below 100 umhg (i.e. micrometers Hg - AKA 'Microns') for a period of at least four hours sans pumping...
FWIW -- Repurposed unused polycarbonate suction canisters represent an excellent source of ulta-inexpensive VCs!Note that 'reusability' is readily achieved via replacement of the adhesive lid bead with a nonadheasive seal (e.g. cured silicone, neoprene, a large 'o-ring', etc)!
By way of elucidation:
Image of a typical 16 liter canister (Spec: DeRoyal Omni-Jug) --- Post continued below image...
Underside of lid -- Please note the 'factory' (adhesive) seal bead immediately inside the 'rim' --- Post continued below image...
Important! -- While I've not experienced same (despite appearance of downright 'scary' stress 'checking'/cracking), implosion of the canister is always possible! - Hence I advise caution! - Meaning use of appropriate PPE and common sense!
Best regards and good luck!
HP![]()
Should your interest in this matter be merely that of educational demonstration/experimentation please be advised that you may forgo vacuum processing with (relative) impunityHi HP,
Alas, I don't have a vacuum chamber (VC).
Do you think i would need a VC for materials like aluminium foil and latex ?
I suppose there are those vacuum food sealers. They basically pump all
the air out of a bag (supposedly containing food) and then seal the bag.
for example: http://www.ebay.co.uk/itm/Andrew-Ja...859879&hash=item5690b930a1:g:~foAAOSwuLZY5f78
And these things aren't terribly expensive.
Sally![]()
Add "dielectric absorption" to the list.some nice phrases for me to look up here:
"leakage resistance"
"self-discharge time"
I'm a little bit puzzled by this whole water thing.
Indeed! the 'catcher', as it were, is to be found in water's 'pesky' 'status' as a nearly perfect polar solventIt might increase the capacitance somewhat but it will drastically decrease the dielectric's leakage resistance, leading to shorter self-discharge time. Many insulating substances become at least slightly conductive when wet.
Sorry if I offended you too. Just an attempt at a joke, my weird sense of humor coming through again. My wife tells me my brains filter system is clogged and it is being bypassed in my old age.Shortbus I had to set record straight on choice of source of latex for dielectric! So anyhow I blame my sometimes coarse sensibilities on growing up in same city that's HP's home town
So being serious I'm sry if I offended you![]()
This will work. Rubber is a form of latex.Hi djs fantasi,
I took a peek at ebay, they have sheets of latex on sale.
See here: http://www.ebay.co.uk/itm/Sheet-Lat...hash=item1c88b5113f:m:mbj0xn6RDO8tvPD_5Ap_cmw
I am assuming, but i am not sure, that this is stuff, described as 'latex rubber' is simply latex.
Sally![]()
Thank you HP,Should your interest in this matter be merely that of educational demonstration/experimentation please be advised that you may forgo vacuum processing with (relative) impunity--- If, on the other hand, you are contemplating construction of electrostatic components for applications requisite of some measure of quality and reliability please be advised that 'two-stage' pumps intended for maintenance of evaporative refrigeration systems are quite acceptable and available at modest cost (often less than $500 USD)
Very best regards
HP![]()
Excellent idea so long as one may be certain the Mylar substrate is free of metallic permeation/contamination -- A (seeming) possibility considering the immateriality of quality control in said regard Re: noncritical manufacturing processes?...I'm surprised that no one has mentioned using the Mylar balloons like they fill with Helium for this. They are made with the same type of process that is used to make Mylar box style capacitors. It is the vacuum deposition process, aluminum deposited on the Mylar under vacuum.
To be clear said units are not part of refrigeration systems but, rather, employed in the maintenance of sametwo stage refridgeration pumps...
IMO Such a device offered new for < $500 is suspect and certain rubbish at < $400I notice, after a quick search on ebay, that (probably inferior) vacuum pumps
are available for as little as 45 bucks.
The mention of "latex" and "dielectric" in the same sentence gave me some very weird thoughts...............................Shortbus I had to set record straight on choice of source of latex for dielectric! So anyhow I blame my sometimes coarse sensibilities on growing up in same city that's HP's home town
I have no idea on what the complete properties of the fluids you've mentioned are... but I'm sure that flammability is a factor considered in their use...After reading about the use of liquid (oil) dielectrics.. i'm wondering why castor oil
isn't universally employed.
You might imagine that 'transformer oil', given that it's used in transformers is the
best insulating oil around.
But not so, it has a dielectric constant of 2.2/2.3
Other plant oils are superior: for example
Cotton Seed Oil and Corn Oil have dielectric constants (DC) of around 3.0
(And so does coconut oil and olive oil).
Linseed oil has a DC of 3.2 to 3.5 (according to engineeringtoolbox.com)
There's a paper recommending the use of Cotton Seed Oil and Corn Oil
See here: Dielectric Properties of Vegetable Oils
(by Shah & Tahir -- 2011 -- in http://www.banglajol.info/index.php/JSR)
But given that castor oil has a dielectric constant of ~ 5.0, or 4.7 according to this site:
http://www.engineeringtoolbox.com/liquid-dielectric-constants-d_1263.html
So .. why is castor oil not used universally in capacitors and transformers ?
Thanks to anyone who might be able to offer a perspective on this puzzle.
Sally![]()
hi cmartinez,I have no idea on what the complete properties of the fluids you've mentioned are... but I'm sure that flammability is a factor considered in their use...
Indeed! -- Along with general poor stability, liability to microbial action is yet another in the veritable litany of 'cons' Re: triglyceride based dielectric compounds! -- You may rest assured that hydrocarbons (Spec: 'high boiling' alkanes) represent a far better choice all around - quite in spite of Chakrabarty's best [worst?] efforts!I guess another consideration might be whether the oil easily goes rancid...
Triglicerids??? I'm beginning to think that arterie-clogged capacitors due to (bad) cholesterol would be a serious issue too!Indeed! -- Along with general poor stability, liability to microbial action is yet another in the veritable litany of 'cons' Re: triglyceride based dielectric compounds! -- You may rest assured that hydrocarbons (Spec: 'high boiling' alkanes) represent a far better choice all around - quite in spite of Chakrabarty's best [worst?] efforts!
As an aside: Truth be told, polychlorinated biphenyl based dielectrics ('Aroclors') are the best! - Howbeit 'rules is rules'
All of which is to say: On my word! Triglyceride based dielectrics are a blind -and, I daresay, rather squalid- 'alley'...
Very Best regards
HP![]()
Well done HP... You were right !Please be advised that dielectric constant and dielectric strength are distinct entities! As a rule triglycerides 'pale' in comparison with hydrocarbons as regards the latter! - As do their thermal and chemical stability!
Very best regards
HP![]()
--Emphasis Added--The central comparison is castor oil to transformer oil.
These values are expressed as KV/inch (Kilovolts per inch)
Castor oil 65.0
Transformer oil 110.7
Inasmuch as you appear possessed of genuine interest in the physical sciences, I strongly advise purchase of The CRC Handbook of Chemistry and Physicswhere should i visit to find these data more easily in the future ?
(Suggestions warmly received)
That - and its poor chemical, thermal and 'bio' stability... Then too, is its hygroscopicity (with corollary liability to electrolysis {among other 'annoyances'}) --- @Sally S - I don't know how else to say it: triglycerides make lousy dielectrics!Castor Oil has a relatively high Dielectric Constant,
but poor Dielectric Strength... this is why, presumably, it isn't universally
used in transformers and capacitors.
HP so you're just saying caster oil caps turn into RICIN krispies when they failThat - and its poor chemical, thermal and 'bio' stability... Then too, is its hygroscopicity (with corollary liability to electrolysis {among other 'annoyances'})
HP you sure can say that againTruth be told, polychlorinated biphenyl based dielectrics ('Aroclors') are the best! - Howbeit 'rules is rules'![]()
