I am having an issue with a few outlets that I think is on the same circut. It started with the light kit in my bedroom fan blowing the bulbs and not working with new bulbs and 2 lamps also blowing bulbs. The outlet tester I have shows the outlets on the circut is wired correct. My MM is showing 2 volts on the left side(ground) of all the outlets on the same circut and 116-117 on the right side. Other outlets in the house show 0 volts on the left and 119-120 on the right. Do I have a bad outlet or an issue at the main box ? In USA. Thanks !
Just checking to see if it is something simple I can check before calling in a pro.
