Hoist speed jog feature
27,714
I am not disagreeing, Max. But none of the equipment that I designed needed a reversing function and so it was not important to the specifications. My reversable winch is a first, previous ones were always purchased by others as complete system packages.
shortbus
Joined Sep 30, 2009
10,049
Maybe the VFD option would give control needed.;)
Max.
But also for the price of just a VFD a chain fall could be bought. And this doesn't even address the brake issue on the electric hoist. I've used over the years electric hoists that had an "inch" button on them, when working with both large/heavy molds and dies, they were still hard to control when you get close to the final position.
And the chain fall could also be used elsewhere if needed where there is no electricity. :)
MaxHeadRoom
Joined Jul 18, 2013
30,704
True, it depends somewhat on the working environment, the ones I have worked on or converted were all used in a production environment for such as loading docks, (Gantry) or small hoists that ofen were fitted/modified for magnet lift for loading parts into a CNC machine etc.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,704
Some were set up for the fixed speed VFD input options, they usually have up to 6 or even 8 set rpm inputs if needed.
But one was a P.B. for normal operation and another P.B. for the low speed jog .
Another could be set up for intermediate speed if needed.
Max.
Model-a
Joined Jun 16, 2009
18
After looking at the VFD connection issues, things become a bag of worms, Shortbus is probably right, I have a CM come along which I can hook to my Budgit hoist hook and use the CM for fine control.
Thanks guys, I've learned a lot from this forum over the years.
shortbus
Joined Sep 30, 2009
10,049
That's what I started out years ago changing engines with. But once I had the chance to help a guy in his garage a chain fall is way better even than a come along. The chain fall is just more even moving, not one notch to the next like the come along.
The electric hoist is great for moving fast, but in an engine change your usually only lifting a minimal height and getting motor mount bolts lined up is much easier with a chain fall/chain hoist. I was usually doing it by myself and the chain fall was the easiest way I found of doing it.
27,714
A heavy duty turnbuckle of a suitable size would give you much finer adjustment ability and be simpler to rig. Really, all of the fine adjustment would be less than 4 inches. And a well greased turnbuckle is not that hard to turn, if it is a finer thread style one.
shortbus
Joined Sep 30, 2009
10,049
You must have forgot how the excess chain gets caught on everything possible
I shortened my "pull" chain so it isn't as long, just about shoulder high now. There is little or no actual strain on the 'pull' chain, the one that moves the lifting chain. You have the same problem with the extra chain on a chain come along.
Model-a
Joined Jun 16, 2009
18
If a VFD was used the brake could be fed from a separate contactor or relay switched off one of the VFD outputs such as At-Zero-Speed etc.
The coil voltage is fed in a typical manner on these types of hoist, off of a bridge in series with one of the motor phases. 230 or 460.
Max.
Model-a
Joined Jun 16, 2009
18
Max.
Max, how does that work to have the bridge in series with one leg of the motor? It seems to me that there would be a voltage drop across the bridge and that leg of the motor would be weak.
MaxHeadRoom
Joined Jul 18, 2013
30,704
Trace the wiring in the drawing, the impedance of the brake is very low.
Also the two pairs of windings are in parallel.
If you feed it separately, it may not take a lot of voltage to energize it.
Max.
