Hitachi 42PMA400E power supply
rastaman46
Joined Nov 17, 2011
75
I have removed diods from board mesuared with multimeter and i have 470v on
Negative to negative and positive to positive
And reads 0 other way round is that ok 470v?
Thanks
bertus
Joined Apr 5, 2008
22,942
It looks like the diodes have been very hot, but are not burned (the PCB is discolored).
Check the large capacitors for bulging or leakage.
Does the meter have a diode test function?
This should read OL (or an other value for open lead) in one direction and about 0.5 to 1 (the voltage for the test current) in the other direction.
rastaman46
Joined Nov 17, 2011
75
Its shows ol in one and 471 in other direction
Traces are fine
What can couse this problem where i need to start looking
Thanks
rastaman46
Joined Nov 17, 2011
75
All caps looks like new
It have fan on supply when i turn tv on fan spins just for split sec then click noise and off again
Thanks
ISB123
Joined May 21, 2014
1,236
The click noise is from the relay shutting down the TV.Since you cant get the error code you will probably have to take it to a repair shop or order a new PSU which is like 60€,check the fuse.
For how long did you have the TV?
rastaman46
Joined Nov 17, 2011
75
Gone true pdf u send me
All was linking to power supply
Then i just gently moved all parts just in case of cold solder
Then pluged cable in boom fan did not gon off
Looked at the screen boom picture
Now testing in case it go funny again
At least i know here power unit cause it
Thanks
ian field
Joined Oct 27, 2012
6,536
Hi all
I got hitachi tv that wont turn on when i press power buton all it does is makes relay clicking noise but wont turn on.
I diasembled tv and on power unit found 2 diods burned
Can any one tell me is diod can cause it please?
Thanks
Discolouration of the PCB is not as uncommon as it should be!
A DMM set to the diode test range should be used to check each diode out of circuit.
Its more likely that something on the load side of things is shorted and activating the PSU overcurrent shutdown.
A relay clicking could be the delay circuit for degauss in a CRT TV - the only thing I can think of a relay for in a LCD TV is possibly inrush surge limiting, either way it probably doesn't indicate much about the fault.
ian field
Joined Oct 27, 2012
6,536
Traces are fine
Thanks
If those readings are from an analogue meter Ohms range, the 471 is pretty much meaningless.
Most DMMs have a diode check range that gives the forward volt drop of a diode - the reading gives some clue to what type of diode it is.
For leakage; you need to reverse the test leads and switch to the highest resistance range - normally any leakage indicates a faulty diode, but Shottky barrier diodes show some leakage as normal - recheck the forward voltage, a SB diode should read possibly as low as 0.2V.
