High voltage protection regulator 100 - 200V range.
Peterperkins
Joined Nov 5, 2018
19
OK I have a low current <10ma drain LTC6090 opamp circuit with a max working voltage of 140V DC.
It's supplied by a battery that varies from 96V upto 150V under heavy charging.
I want to design a simple voltage regulator that will limit any voltages over 130V to 130V for my opamp circuit.
I looked at simple 130V zener types but they seem to waste a lot of power when it starts to conduct and require a fairly big wattage resistor in front of the load which causes a voltage drop.
I don't want a crowbar circuit to short it out just something to limit the voltage to 130V..
I have 400V P Channel Mosfets available along with 130V zener diodes etc.
Thoughts
danadak
Joined Mar 10, 2018
4,057
Why not just insert a zener in series with supply to OpAmp
circuit ?
Supply >> Zener >> OpAmp Circuit
No passive R to throw away power, just power consumed by Zener and current thru it.
Regards, Dana.
