high temperature cable and connector
Pan Tong
Joined Apr 26, 2015
50
Hello:
who can recommend me connectors can be used around 150--200 Celsius temperature?
normal cable to cable connector all rate under -40--+105 Celsius
I saw butt/Posi-lock connectors like
the insulation material also just can reach 150 degree
is it really no such of insulated connector can be used under 150--200 degree environment ?
thanks and regards
dl324
Joined Mar 30, 2015
18,467
Have you tried a WEB search? Or checking manufacturer websites? I found connectors rated at 250-400C without much effort... Requiring insulated connectors reduces options...
Pan Tong
Joined Apr 26, 2015
50
Hi Dennis:
thank you for your reply
I did do a lot of search, still can't find a insulated connector can withstanding up to 200 degree :( , just wondering it is true or not
BR-549
Joined Sep 22, 2013
4,928
200 degrees C.....that's warm.
What type of insulation is the wire using?
Can you rewire, not requiring a connector?
Pan Tong
Joined Apr 26, 2015
50
I can find cable with insulator meet the requirement, but not sure the price
but why no connector can support this temperature ?
thanks
BR-549
Joined Sep 22, 2013
4,928
That insulation is right at your limit.
You want a rating of at least 300.
I would want 500. Overkill is advisable with heat.
BR-549
Joined Sep 22, 2013
4,928
We used to use asbestos sleeves for high temp apps.
Might be outlawed now.
I am not up on it.....but maybe some thermocouple wiring accessories.
There will be experts on line in a few hours.
You'll get fixed up. Be patient.
