High precision manual trimmer component question
yef smith
Joined Aug 2, 2020
1,481
Hello , I have a trimmer (knob variable resistor )
Unfortunately when I turn the knob it resistance turns in a very high rate .
Is the a trimmer for example of 1Kohm
Which will cover its range in 5 times more turns than usual?
Thanks.
Jerry-Hat-Trick
Joined Aug 31, 2022
849
Please clarify - what is your question? Typically a trimmer is used to adjust a fixed resistor value placed in series with it. The trimmer should not be more than 1/10 the value of the fixed resistor. You can get single turn, 10 turn, 20 turn and sometimes other values to go from around zero to their specified resistance. What is your application and what range of adjustment are you looking for?
tonyStewart
Joined May 8, 2012
238
Re-phrase your question?
"knob" trimmers ? multi-turn pots? trimpots ?
Each mean something slightly different.
How to avoid or use of trimpots with high precision?
How to optimize sensitivity, accuracy and stability with environmental conditions with precise easy adjustments?
What features are important? performance, cost , stability?
