High Current Regulator Problem
gunvald
Joined Oct 16, 2013
15
I've been trying to this on my breadboard hoping to get more current from my lead acid battery of 12V 4Ah and I can't get it to work.. The current draw is much higher when I directly connect it to the battery(about 1.3A) than when it is connected in the circuit(1.07A ~ 1.17A).. I want to amplify the current to suffice the needed optimum input for a 60W Peltier(TEC-12706).. Can you recommend me any other circuit that can output a constant 5A and can supply at least 2~3 60W Peltier.. Thank you in advance.. Any help will be greatly appreciated..
38,505
A linear regulator can only regulate voltage, it can't increase the current (current out ≈ current in). It's output current would be expected to be less than the battery directly connected, since that regulators maximum output voltage is about 4V less than the battery voltage.
Did you measure the battery voltage when it is directly connected to the TEC?
If you draw 15A from your battery it will last less than a quarter hour.
You need a bigger battery.
gunvald
Joined Oct 16, 2013
15
I did measure the voltage on the battery and it's about 11.78V.. How can i draw the needed current on the battery? I can't seem to figure out how it works, I even tried connecting a 2.5Ohms resistor in series with the peltier and still get 1.3A.. Thank you again.
P.S I'm not very knowledgeable in electronics, hoping for your very kind consideration in assisting me.
MikeML
5,444
That is very poor current booster for the LM317. Do you want me to show you one that is recommended by TI/National (the maker of the LM317)?
MikeML
5,444
I looked at the specs for this cooler, and I cannot see any reason to use a voltage regulator between a 12V SLA battery and the cooler. A fully-charged SLA will be about 12.8V initially, and you should stop discharging it when its voltage falls to about 11.5V. During this time, the cooler will operate just fine, even as the voltage drops between these two values. No regulator is required.
Now, as pointed out earlier, a 4Ah battery will run this cooler less than 40min before the battery needs recharging...
gunvald
Joined Oct 16, 2013
15
My problem is that the battery only supplies 1.3A.. how do I pull the 5A from it? Thanks.
MikeML
5,444
The reason that your battery only puts out 1.3A is because it is totally discharged, and needs charging. Or the battery has been sitting around discharged for months to years, and is now worthless. When in storage, a lead-acid battery needs first to be fully-charged before being put in storage, and then to be periodically recharged (at least once a month to replace the charge lost due to self-discharge). If you do not do this, you permanently damage the battery, and might just as well recycle it and get a new one...
A fresh fully-charged 4Ah 12V SLA would put out a peak current of >~20A (but not for very long)!
gunvald
Joined Oct 16, 2013
15
Thank you very much, I will now start charging the battery and see if I can pull out the current needed..can you still teach me how to boost current though? and is it still okay to use a discharged SLA(discharged it to 10.5V :()? I didn't know that it's not suppose to go down below 11.5V.
Once again, Thank you very much for helping me out..:)
38,505
As I previously noted your circuit cannot "boost"the current.
It can regulate or limit the current but not increase it over what the battery will give all by itself.
ScottWang
Joined Aug 23, 2012
7,501
And since that regulator is worthless, and the TS doesn't need a regulator in the first place, then this suggestion is worthless, too.
Something that he should do then he have to do, otherwise when he solve the battery problem, we can't make sure when the 2n3055 will be damaged.
gunvald
Joined Oct 16, 2013
15
I'm back and still got the same problem.. I managed to charge this battery to 13.5V (dunno if it can go higher).. I got a little boost of current after charging.. From 1.3A ~ 1.8A.. but I still can't get the required 5A to maximize the peltier's cooling.. I also measured the voltage again going to the peltier and found that it's only about 10.1V.. is it possible that my battery is defective?.. I hope you continue guiding and helping me with my problem.. Thank you.
MikeML
5,444
Battery is shot. Replace it. If it was still good, after charging, it should deliver a peak current > 20A. That fact that it does not means it has been left sitting uncharged too long, or it was previously incorrectly charged.
gunvald
Joined Oct 16, 2013
15
Is there no other possibilities that affects it? ex. Peltier itself.. it is rated at 60W yet it draws only 1.3A ~ 1.8A.. I also tried supplying it directly from a wall adaptor rated 12V @ 5A but when I connect the ammeter in series, the peltier draws only 2A max.. And is it safe to use a 12V @ 12A adaptor for the supply? Thanks again.
38,505
If the voltage at the Peltier is less than the supply voltage then there's a voltage drop between the two.
What size and length wires are you using to connect it?
Note that the ammeter itself has some resistance.
