Hello everyone,
After having built quite a few amplifiers (most class A), I wanted to decide to take on a class AB amplifier. My issue lies with the output stage. I've drawnup a basic design (I'll attach below) that allows for a 4 volt swing across an 8 ohm load for 2 watts of output power. The only issue I've got is the power supply. I need a +10 and -10 supply, and I've only got a 10v 2A wall wart. I've heard of splitting the supply with a divider, but that didn't work for me (the emulated ground's potential kept changing), and the classic 555 negative voltage rail simply couldn't supply the ~400mA of current needed for the 8 ohm load.
TL;DR: does anyone know of a schematic that could produce a -10v, 400mA rail from a +10V, 2A rail?
