... something is not right with the diode measurement test.
I tested a known good discrete diode. The red plug was on the anode end and the black plug was on the cathode end ... the one with a white stripe. This forward bias activated the diode test function on my multi-meter and showed a value of 0.613 volts ... indicating a good diode. When the plug leads were reversed, the reading was infinity, indicating that no conduction was present. This was the expected result, and should be the same when testing the back-to-back diode junctions of a transistor.
... So try using the red and black plugs of your meter, and just plug them normally into the usual jacks on your meter.
... Another point of confusion, I mistakenly described one of the transistors that were to be tested.
Only transistors Q524C and Q524A are suspect at this time. Q524C is NPN type. Q524C is PNP type.
... I was thinking that you were going to try using the meter Hfe test function, which should show a number of 2 or 3 digits, but something was evidently wrong there. Did you have the meter turned on? ... Maybe the three leads were not connected to the correct transistor pins. The Hfe measurement is made by connecting the e,b, and c leads between the transistor and the meter Hfe test holes and the turning the meter on and switching the dial to which Hfe transistor type you want. A number will appear in the readout. No rearrangement if the test wires is necessary. Just read the number that is displayed.
