Hi everyone, I want to know the counterpart BJT for iRF630 and iRF9630. For my school experiment.
38,503
MOSFETs don't really have BJT counterparts, since their operational characteristics are so different.
What do you want the BJTs to do?
Oh wow, I am going to watch this topic just to learn something.
NPN and PNP counterparts for N- and P-channel mosfets? Apples and oranges?
I suppose that one would pick a common characteristic or two to at least *try* to base the counterpart claim on.
Maybe power dissipation, or maybe continuous current, e.g. - continuous drain current vs Ic?
What do you think?
phranzdan
Joined Aug 4, 2017
40
HI: The IRF630 is rated at 200 volts and 9 amps with an Rdson of about 0.4 ohms. The IRF9630 is rated at 200 volts and 6 amps with Rdson at 0.8 ohms max. Understanding that the drive requirements are different for bipolar versus mos, you would need to select a bipolar device with a BVceo of at least 200 volts and a 6 to 8 amp current rating. The other parameter is Rdson. Take an IRF630 switching 5 amps. The dissipation in the device would be 5 squared X .4 or about 10 watts with the device biased at 10 volts Vgs. The 200 volt Bipolar Device dissipation would depend on the Vcesat. Say we used a forced beta of 10 then the base current at 5 amps would be 500ma. I don't have my old transistor manuals, but I'm guessing the Vcesat would be about 1.5 to 2 volts. The dissipation in the collector emitter junction would be P=EI or 2 x 5.5 = 11 watts. Note that the Vcesat of BJT's gets higher as the voltage rating increases since the resistivity of the silicon increases. This just a simple case of finding a BJT with similar ratings to a Power Mosfet. We also should note that the Rdson can be reduced by using higher cell density Power Mos. Another device, the IGBT(Insulated Gate Bipolar Transistor) combines the best of both worlds with a MOS gate and a bipolar structure in the collector emitter. These are commonly used in switching applications such as switch mode power supplies and Generators. I hope this helps a little.
38,503
Without knowing what the transistors are used for, it's kind of a crapshoot as to what BJTs would work in place of those MOSFETs.
iamprincejoy
Joined Aug 7, 2017
25
Thats the schematic diagram for our experiment, my professor, he wants to replace the mosfet with bjt.
As I observe in experiment the irf630 is for positive cycle sine wave and the irf9630 is for negative cycle sine wave.
GopherT
Joined Nov 23, 2012
8,009
That amplifier is a mess if intended for audio signals.
Mosfets don't work well in that application - especially without your feedback loop going all the way from the op amp to the mosfet output (which will require more changes).
What are you trying to do? Simply amplify an audio signal?
Jazz2C
Joined May 27, 2016
52
Just for my experiment subject.
Thank you for helping.
There aren't counterparts of field effect transistors among junction transistors! They're two entirely different semiconductor topologies! It looks to me like your assignment is to design an equivalent circuit around BJTs which isn't the same as the BJTs being equivalent to the FETs!o_O
Tnx for that! I knew it couldn't be just me!
iamprincejoy
Joined Aug 7, 2017
25
Yes sir, To amplify audio signal, in our experiment we are using audio generator for our audio input.
My professor want to replace the mosfet with BJT but the op amp is still there.
And he said that ones we have replace a BJT we need to prove the computation.
GopherT
Joined Nov 23, 2012
8,009
You say he is a professor. I assume he is not a professor of electrical engineering. What kind of research?
iamprincejoy
Joined Aug 7, 2017
25
what he want is to replace the circuit with transistorize.
He let us to research for the circuit.
GopherT
Joined Nov 23, 2012
8,009
Start over and try something like this. It is not perfect but it is simple.
Also, my schematic does not show the +/-12v to power the op amp.
Please use a modern op amp instead of the 741
Also, the bjt need some biasing and help with cross over distortion, hence the diodes and resistors.
Also, I pulled the feedback loop all the way to the output speaker to improve performance.
iamprincejoy
Joined Aug 7, 2017
25
What is the value for transistor and diode sir?
