HFE question
ckaiser813
Joined Jan 21, 2009
17
First time post my lab says this,
assuming hFE is 165 and hfe is 120 for the transistor displayed in the amplifier calculate the voltage gain, AV, of the amplifier.
Anyone have a formula for me, I already calculated VB and IC in the previous questions if that is what I'm looking for.
Thanks
Chris
mik3
Joined Feb 4, 2008
4,843
Then calculate gm=IC/25mV and if the amplifier is a common emitter one the AC voltage gain will be approximately gm*Rc. Rc is the resistor between the collector and positive supply rail. If you want post the circuit to be sure of the result.
Wendy
Joined Mar 24, 2008
23,797
So did I with another thread, and got bit. :rolleyes: That's why I put up the schematic (version 2), it helps pin things down.
mik3
Joined Feb 4, 2008
4,843
For the ac voltage gain to equal gm*Rc//RL, you have to bypass Re with a proper valued capacitor otherwise the gain changes. Also, the gain equals gm*Rc//RL for mid band frequencies. For low and very high frequencies the gain reduces due to capacitances in the circuit (coupling and bypass capacitors and the internal capacitances of the transistor).
Wendy
Joined Mar 24, 2008
23,797
Actually, with this circuit gain is the simple Rc/Re. I'm not sure what "gm" is (but am interested). The original drawing had a emitter swamping resistor, but it tends to confuse the issue with the reactance equations, and the gain without the emitter resistor becomes an issue of transistor frequency response and frequency. I assume the capacitor reactance is negligable for the most part on these kinds of designs, after pinning down what frequencies they don't interact much.
I don't mean to hijack this thread however. Want me to draw another one with the capacitor?
If I don't know what gm is, what are the odds the OP does?
mik3
Joined Feb 4, 2008
4,843
gm is the transconductance (Ic/Vbe) of the transistor and it has units of Siemens. It is used when you make calculations using the pi model of the transistor.
italo
Joined Nov 20, 2005
205
Hfe is an inpirical number for an Ic current, is defined as base current to cause Ic to flow by that factor only if the current is within device specification. For hi amps this inpircal number can and will drop substantialy. An Hfe OF 165 at 50 ma can drop to less the 5 at 1-2 amps.
Audioguru
Joined Dec 20, 2007
11,248
If the transistor has enough current gain to be biased correctly then the hFE or hFE has nothing to do with the circuit's voltage gain.
The voltage gain= (look in a tutorial about transistors).
