Heltec V3 TX-repeater-RX
camerart
Joined Feb 25, 2013
3,853
I was given some Heltec V3 units as presents. They can be programmed by Arduino. I'm no programmer, especially Arduino.
I wondered what would be a useful use for them. They are low powered (UK 25mW) and consume little power.
I thought that they could be useful in an emergency, like a lost person or similar.
Using AI, I have got
1x as TX reading GPS.
1x as repeater. This could be place high, or even on a balloon, or drone.
1x as RX, which shows coordinates, time, date and count number on it's screen.
I'll be testing the range soon, and will let you know.
(Also on ETO)
Cheers, C.
camerart
Joined Feb 25, 2013
3,853
As there are no replies, I assume that no one's interested?
Anyway, I (AI) modified the 3x programs BASE-REPEATER and REMOTE, so that GPS is toggled backwards and forwards between them, so each end sends it's own GPS data. This would allow me to verify that messages are getting to both ends.
I used 4x frequencies, so that crosstalk between BASE and REMOTE can't happen.
(Also on AAC)
(P.S. I found out that GPS is only the American GPS, so as I'm not an American I should call it GNSS, but I won't :) )
C
meth
Joined May 21, 2016
322
So what is it we aint interested? :D
The project seems interesting, but there is no "hook" for a discussion. If you test the solution and share the results/problems faced there might be something to talk about.
camerart
Joined Feb 25, 2013
3,853
Hi M,
At the moment I'm testing the range, using a REPEATER.
Once tested I will try different projects, i,e, Emergency search and rescue-Triggering a camera-Security-Remote control, and whatever my imagination comes up with.
C
meth
Joined May 21, 2016
322
In my opinion in parallel you should think about logging the movement, it could be interesting to mount it on an alley cat or stray dog to do some research :)
camerart
Joined Feb 25, 2013
3,853
Hi M,
This is a good idea, however these modules are low power and my tests would usually need a repeater, to assist mostly line of sight, and folliage. Do you know how to do it?
I'll look into it.
C
camerart
Joined Feb 25, 2013
3,853
Hi, (Testing with no REPEATER)
I've had BASE and REMOTE kind of synching , with each other reading GPS and Txing while showing GPS on screen, then showing RX on screen.
If they both start at the same time, then they won't be RXing as their TXing, which also has to take into consideration, loss of GPS or loss of RX, then re synching.
They need to toggle like passing a Baton between them. (I did try this)
Any ideas please?
(Also on ETO)
C.
meth
Joined May 21, 2016
322
I would say you need some kind of handshake, first a module should ask "are you ready to receive" , if the answer is YES send the data, if the answer is NO (or should I say - no answer) store the data in buffer and ask again after 3 seconds. When NO becomes YES send the entire buffer of data and wait for feedback. If feedback is received clear the buffer.
On the other hand the receiver, while idle, upon "are you ready to receive" message should ignore all other messages until data buffer is received. If the buffer isnt received in 5 seconds, become idle again. You can also make a priority list, if one device sends data 3 times in a row, ignore next 3 sends (data would be kept in buffer) until the other device makes a send.
camerart
Joined Feb 25, 2013
3,853
Hi M,
Note: For clarity, I use BASE and REMOTE, as both are TX and RX.
I've tried various versions similar to what you say.
Both modules read their GPS NMEA sentence string, then parse it and show it on their screen, while TXing this data, and RXing the others GPS data, then show that on their screen.
I've been showing each data on the screen for 15 seconds each.
Note, that the GPS and opposite data signals could be lost.
C
Actually, it’s an interesting idea, especially the repeater-on-a-balloon/drone concept for emergency location sharing. Low-power LoRa + GPS can be very useful in areas without mobile coverage.
I think people are probably waiting to see the real-world range tests and reliability results. It would be interesting to know how stable the links are and how much latency you get through the repeater.
camerart
Joined Feb 25, 2013
3,853
Hi F,
So far I've got a range of approx 1xmile, in poor conditions.
As I can't code, I'm using an AI to do it, which is great, but it's a bit 3 foot forward and 2 foot back, when the AI goes of on a tangent. I'm still getting used to it. I'm stuck with an Arduino library problem at the moment.
As for an ACK, I imagine an ACK is for making sure a message gets to the other end, each end kind of acknowedges, by returning a message.
The method I use it ech has slightly ofset TX timings, so the clash occassionally but mostly are open. A received message has either an A or an X at the front which serves as an ACK.
C
