5.8GHz FPV video repeater
Spirito1
Joined May 5, 2026
Hello everyone,
I'm building a 5.8GHz FPV video repeater and I'm encountering a problem I can't seem to solve.
My setup:
- Drone transmits at 5705 MHz
- RX5808 receives the drone's signal
- Video output from the RX5808 to the video input of the TS5823
- TS5823 retransmits at 5865 MHz to my monitor
- 75Ω termination resistor between Video OUT and GND
The problem:
When I receive the drone's signal directly on my monitor at 5705 MHz, I get a perfect image. But when I pass the signal through the repeater, I get organized noise at the RX5808 output (structured lines, different from the random noise of unused channels).
What I've already tried:
- Replacing the RX5808 with a new one, same result
- Adding a 75Ω resistor between Video OUT and GND
- Checking the power supply, it's stable
- The RX5808 is configured to 5705 MHz (all channels at 0 = 5705 MHz)
The radio signal is received correctly by the RX5808 (organized, not random, noise), but the video output is unusable.
lipo 8v 2s -> diode schottky sr3010 -> fuse 3A -> ts5823 (5865mhz) -> star ground
-> BEC 5V -> RX5808 (5705mhz) -> star ground
-> Video rx5808 -> TS5823 with 75 ohm impedance
every thing that need 100nf, 10uf filter have one
Please help me find the origin to the problem
