Help with wah wah pedal potentiometer
lokeycmos
Joined Apr 3, 2009
431
im building a wah wah effect pedal. i have the circuit built already. it uses a 50k log pot with 300 degrees of rotation. this is a problem because the pedal is going to be about 45 degrees. i attached a drawing of what i think will work. i just need some help calculating the values. i think that to get the full range of resistance i will need a larger pot to go with the external resistors. thank you :)
lespaul
Joined Jan 30, 2008
49
Guess I am not quite understanding the question. Looks like the schematic is correct....Craig Anderton is a solid designer.
The 50K pot will give you an adequate filter range in this circuit.
lokeycmos
Joined Apr 3, 2009
431
i guess what im trying todo is reduce the number of degrees from 300 as is, to about 45 degrees for a pedal while keeping the resistance range.
bribri
Joined Feb 20, 2011
143
it's a mechanical solution i think. pedals such as this will have a grooved 'knob', or sprocket rather, and a grooved stick dangling from the pedal.
i think i've seen a kind of 'belt' system to do this also.
