I'm trying to make a voltage-controlled distortion circuit (see attached schematics). The idea is similar to PAiA's Quadrafuzz module:
http://www.paia.com/ProdArticles/quadrafz-design.htm
..except I'd like to add voltage-control (or CV in the synth world) to each channel. I don't want to blindly build PAiA's design, but instead re-design it based on my understanding how the circuit actually works - which isn't too complicated (besides the extra circuitry at the output for feedback and loop send/receive which I don't quite understand). And I'm also adding a wet/dry circuit to for mixing distorted/clean signal.
So the idea.. the input signal splits off into 4 frequency bands/channels, then each one's distortion is independently voltage controlled, and then all channels are summed and re-scaled at the output. Note, my attached schematic has the input/output section on page 1, and only one of the four freq + distortion channels on page 2. There's no global (input-to-output) feedback or anything either - don't really need it (..I think?). So it's a pretty straightfwd circuit.
The part of the circuit which adds the distortion is a variable feedback resistor based on the LM13700, wired as a floating resistor per the datasheet's cryptic wiring (see figure 28 - bottom of page 16 on the datasheet:
http://www.ti.com/lit/ds/symlink/lm13700.pdf).
This circuit actually works, but there are several (some big, some small) problems. Here are just a couple for now..
1) Distortion is subtle and not very prominent. I'm using LEDs in series with 4148 diodes to do the clipping. But I want the clipping to be at a higher voltage. Should I just add more diodes in series with the LEDs? Also, I'd like the LEDs to be brighter when they’re clipping (right now they're quite dim).
2) The wet/dry circuit (on page 1) doesn't really work, because the signal is always pretty wet. There has to be a better way of mixing wet/dry signals.
Any advice, suggestions, or comments are welcome
Thanks you!
Thanks you!
