You say you want the signal across R9, which is an usual way to use the signal from such a circuit since that requires some sort of differential circuit to detect the signal.
Normally the signal is taken from the transistor collector to ground.
How are you going to use the signal across R9? Where is it going?
What do you want the output signal to do with a -15V input?
