Help with Thevenin equivalent
ericgibbs
Joined Jan 29, 2010
21,628
hi Ylich,
Welcome to AAC.
As this is a Homework assignment, please post your attempt at answering the question, we can then guide you through the problem.
E
Ylich
Joined Apr 27, 2019
Oh sorry, oke thanks. This is what i have got. I assume that i know the value of Rg, Vcc, R1, R2, an Vin(t); so i have 3 unknown values: Rth, V'in(t) and Vbias; then i have 3 unknown values and 2 equations, is that ok?. By the way, do you use any software to draw circuits?
Ylich
Joined Apr 27, 2019
Is there a method that gives you both in one? Can i use thevenin when the circuit mixes both dc and ac sources?
WBahn
Joined Mar 31, 2012
33,321
Not really. The whole idea of a Thevenin equivalent requires that we be talking about a linear circuit. But the large signal behavior of most transistor circuits is very nonlinear. So what we normally do is treat the circuit as two circuits superimposed -- a DC circuit and an AC circuit with the excursions of the AC circuit being small enough that we can pretend it is linear, at least over the range of the excursions and at least to a degree that is acceptable for our purposes.
