Hello All,
I have a really simple question for all of you; not so simple for me or I would not be here!
I think I need a diode but don‘t know what kind. I am hoping you can help. It will be quite obvious this is not my primary job.
Here is the situation:
I have a prototype device that I am trialing for a company. The device is very clever and use is a 24 volt DC motor that is controlled by a simple SPST switch that has an LED dependent light that turns on when the switch is closed. Simple enough. However I noticed when the SPST switch is opened and the motors is spinning down the LED continues to faintly glow! What appears to be happening is that the motor as it is spinning down is acting as a generator. I confirmed this by measuring a potential of 4VDC as it spinss down. I would like to eliminate this potential since other sensitive electronics attached to this circuit might not like this. It seems to me that a diode is what I need to prevent “backflow” from occurring as the motor spins down.
Can anyone recommend a diode? Again, the voltage is 24VDC, although I did not measure the current in the “back flow“ direction, in the forward direction it is never greater than two amps and so is almost certainly much less than this.
I apologize for the simplistic language but would greatly appreciate anyome’s help!!
Thanks,
Mike
Thanks,
Mike
