MisterBill2
- Joined Jan 23, 2018
- 28,331
Caution is needed because the two "ground" symbols are DIFFERENT, and on a circuit board that is a cheating way of tying things together, but not always a ground. So perhaps that capacitor in series is also suspect, possibly of breaking down under higher voltage but not staying short circuited.That is really a weird way of wiring things up. Notice the 'output' of the power amp is tied to chassis ground. Then the speaker is tied between chassis ground the the power supply common. IOW, the 'hot' side of the speaker out is connected to the chassis instead of the 'cold' side.
In any case, the resistor is indeed part of the Zobel network.
AND, after an additional examination, I see at least FIVE Different "ground" symbols on the schematic drawing.That means that there are isolated networks that are not connected to each other except where they are shown to connect.
What great way to confuse anybody who may want to service this package!
