Help with pspice
Matherios
Joined Feb 25, 2018
74
How can i calculate the power dissipation on a mosfet and also is there any way i can calculate the Rds(on) of a mosfet?
Jony130
Joined Feb 17, 2009
5,599
Can Pspice do waveform arithmetic on its plots?
Yes, it can do it. Just like any spice program.
Is this some kind of a homework question?
But first of all your MOSFET (BS250) is a P-channel MOSFET and you got it connected wrongly on your diagram.
As it is now your MOSFET behaves like an ordinary diode connected between the drain and the source.
Lika I show here
Because you have forgotten that every single MOSFET will have a built-in body diode.
This diode is even shown in the datasheet
https://www.vishay.com/docs/70209/70209.pdf
So, this body diode will conduct all the time and the Rcoil voltage will be around (12V - 0.6V) = 11.4V and the current is 11.4V/360Ω = 31.7mA.
And the power dissipation on a mosfet is P = 0.6V *31.7mA = 19mW
Now if you properly connect your MOSFET (swap drain with the source)
The "body diode" no longer conduct any current because as you can see the "body diode" is in reverse biased.
And the MOSFET can now work properly as a switch in this application.
And in datascheet we can find Rds(on)_max = 14Ω if Vgs = 10V hence the P = (12V/360Ω)^2 *14Ω = 15.6mW. But typical power dissipation in the MOSFET will be lower than this becouse Rds(on) will be typical in the range of 4Ω.
Also what is the purpose for a R2 resistor?
Matherios
Joined Feb 25, 2018
74
r
Lika I show here
R2 resistor is if the nand gate gets destroyed we will be sure that 0 volts will go to the mosfet.
Matherios
Joined Feb 25, 2018
74
On pspice im finding the PD=219,89mV(voltage drain -source)*IL=32.72mA=7.26mW and my calculation were Pd=14.41mw.
Can the difference be so big or am i doing something wrong?
Jony130
Joined Feb 17, 2009
5,599
Which book? And maybe in the book, they are using N-channel MOSFET instead of a P-channel one?
As you can see here
To "open" (drain current (Id) will start to flow) the P-channel MOSFET the voltage at the gate need to by at least Vgs(th) lower then the voltage at the source of a MOSFET.
Have you corrected the circuit diagram?
Matherios
Joined Feb 25, 2018
74
As you can see here
The circuit is supposed to be like that this is our homework im not doing something wrong.
The circuit is supposed to be like that,that's our homework(i think that the mosfet is rotated so we can have posotive voltage to drain and negative to source)
Jony130
Joined Feb 17, 2009
5,599
But this circuit will only work as it should only when the source terminal is connected to the positive terminal of a voltage source and the drain terminal is connected to the Rcoil side.
Because now with the drain connected to the positive side of a battery the "body diode" will conduct the current all the time and the relay will be energized all the time also, independent of a gate voltage.
As for the power dissipation, because we do not know the exact value for Rds(on) we cannot get the exact resoult for Ptot in the transistor. We can only find the worst case power dissipation.
