Help with Precision Rectifier Circuit
YWK
Joined Jan 29, 2015
3
Been working on precision rectifier circuit to rectify a sine wave +-4V generated using an Arduino & corresponding circuits (to represent an Hall Effect Current Sensor). The problem with the circuit below is that i am getting a full wave rectified signal but unequal amplitudes for diff half cycles. I did a simulation with LTSpice and it gave me the signal i wanted. Perhaps its the component i am using or?
Op-Amp : TL072CN -> +-12V supply
Diode: 1N5817
Resistors: 1% Tolerance (don't think its precision resistors?)
R1 = 2 47kohm (in series)
Circuit from (http://sound.westhost.com/appnotes/an001.htm)
Will post a picture of circuit i soldered when i get back.
Any help would be greatly appreciated.
YWK
Joined Jan 29, 2015
3
It seems like the 1N5817 Schottky diode caused it, i am guessing. I followed the quote within the TI datasheet posted about using 1N4148 silicon diode, and something to do with larger leakage currents that comes with the Schottky diode. I replaced the 1N5817 diode with the recommended 1N4148 diode and the circuit is giving me a full-wave rectified signal with equal amplitude. Can't seem to understand why....perhaps my Schottky diode was faulty? Or perhaps it has something to do with the nature of the Schottky diode itself which made the circuit produce a unequal amplitude fullwave rectified signal?
I am quite happy that it is all working now and thx for the help posted. If i had time, i would be most interested in finding out why but if anyone out there has perhaps a clue on why the diode choice made a difference, pls do advice.
Once again, thanks for the advice given. I am a newcomer here and would definitely be coming back for more help from the community for any projects (university/hobby).
YWK
Joined Jan 29, 2015
3
Also, i think it was important to note that when I measured resistance the individual R2 & R3 resistor when it was connected in the circuit with the 1N5817 Schottky diode, I didnt get 100kohm, when i clearly used a 100kohm resistor for R2 & R3 (measured before soldering). I got something like ~60kohm for both which i found odd.
After changing the diodes, R2 & R3 gave me 100 kohm on the multimeter. Just wanted to note that.
34,450
Schottky diodes have significantly higher reverse leakage as compared to PN junction diodes and that likely is the cause of the asymmetry.
GopherT
Joined Nov 23, 2012
8,009
Be careful when you measure high resistance diodes. If you hold them in your fingers, your skin will be measured in parallel and can make it appear like your resistance is much lower than reality. Best is to clamp the ohm meter leads to the resistor and keep your hands off when reading the value.
