Help with Op-Amp Voltage Follower
whitehaired novice
Joined Jul 15, 2017
289
So I was Googling high input resistance OP Amps and ran across a LM11 which rang a bell in my memory--sure enough, I have a couple in my asst. So I'll try that a while and if it comes closer then I'll get the one you mentioned. Thanks again. By the way, "Try again" in my time line is sometimes a week, sometimes only a day.
danadak
Joined Mar 10, 2018
4,057
When browsing Digikey you are using the filters for the product suggestions
displayed in Excel ? That will cut down a lot.
Regards, Dana.
27,587
For some useful information, check the December edition of "analog dialog", an on-line publication of Analog Devices company. It has two discussions about instrument amplifiers. And one of those devices has the specs that your application can use.
whitehaired novice
Joined Jul 15, 2017
289
@ebp OH YES! I put a op amp between my 10k pot and the input of a second voltage follower made from a LM11C which I happened to have. This is claimed to have low input Offset Voltage and Input Bias.
Everything worked smoothly. Then I put a 70 megohm resistor (don't ask--just an impulse buy some months ago) in between the output of the first op amp and the input of the second. And I got a drop from 3.4066 volts to 3.4058 volts. I can't even contemplate what the actual input resistance is, but it is plenty for my purposes!
I'm going to put the circuit on a board and proceed. I wouldn't be here if it were not for you and others offering guidance and encouragement to an old man whose last electronic experience was with KT88s and 12AX7s.
27,587
At those obviously "high" impedance levels you need to be aware of leakage paths and materials that act like capacitors having charges stored that lead to confusion. Bob Pease wrote a number of very educational documents about the effects, if you can find copies of his publications the education is worth the effort, big time.
27,587
