Can you help?It depends upon the application, which is??
Where do I get those?You'll get more help if you make it easier for someone to help you. Post a schematic and the datasheets.
From where you bought them, manufacturer, Google,...Where do I get those?
similar but different.From where you bought them, manufacturer, Google,...
They look fairly equivalent, but a schematic showing usage would allow critical parameters to be identified and scrutinized.
The first pair of numerals relate to Id, 13 is better than 12, so using a 12 instead of 13 is probably asking for it.Hello. It's a 51 inch Samsung plasma TV power supply.
Did you test the ones you took out?Tried them in but no change. The fault must lie somewhere else. Maybe someone on here as had a similar fault with one of these TVs. Stuck on standby. Screen flashes white and led flashes.
I only tried the mosfets as Google and YouTube are suggesting. Have worked on other Samsung TVs that just needed capacitors replaced but all caps are good. Not too sure about the old ones. Using a cheap meter. The meter says the vs and va voltages for the screen are too high.Did you test the ones you took out?
Most often they fail short circuit all ways round. That usually takes out any fuse, possibly a resistor or two and maybe even a PCB track.
It might simply be not starting up - there are various schemes for getting it going, the most common is a high resistance start up resistor. These can be in the habit of going high or open.
Most likely a safety trip shutting it down then.I only tried the mosfets as Google and YouTube are suggesting. Have worked on other Samsung TVs that just needed capacitors replaced but all caps are good. Not too sure about the old ones. Using a cheap meter. The meter says the vs and va voltages for the screen are too high.
Be very careful connecting a 'scope to measure waveforms in the psu, as unless the T.V is run from an isolation transformer, you will either damage the scope or psu as the "earth connection" of the probe will short out the psu. Under no circumstances be tempted to just remove the mains supply earth from the scope to measure the waveforms as it will float the case and internals at line level. This practice has killed more than a few engineers in the past!If it were me, I would rather get the exact part, or at least one in the same package. Heat sinking will be an issue.
The second thing to worry about is whether the MOSFET took anything else with it when it burned out. After extracting the original part, use an ohmmeter to see whether there is any resistance between drain and gate. If there is anything but infinity, then in the process of burning, a current path was created between drain and gate, probably putting a high voltage on the gate, and destroying the driver circuit. If you have a scope, you might want to see whether the driver circuit is still putting out a waveform. Also check any diodes you see in the vicinity, and nearby resistors, even if they don't look burned.
The third thing is whether whatever burned the MOSFET out in the first place is still lurking in the circuit.
Its a trick I got away with for a long time - but it did bite me every once in a while.Be very careful connecting a 'scope to measure waveforms in the psu, as unless the T.V is run from an isolation transformer, you will either damage the scope or psu as the "earth connection" of the probe will short out the psu. Under no circumstances be tempted to just remove the mains supply earth from the scope to measure the waveforms as it will float the case and internals at line level. This practice has killed more than a few engineers in the past!
Electroytic capacitors used in non critical applications, ie tv power supplies, may often have a value tolerance of -50/+100% of the stated value. So if you are measuring only the value, it is possible that for example, a capacitor marked 100mfd, may have had a value of 200mfd when new. Due to ageing and deterioration, may now read only 100mfd, BUT, the equivalent series resistance may have increased significantly now rendering it unable to perform its function correctly. in switch mode power supplies, the ESR is often far more important than the exact measured capacity. Anyone who repairs things like the smp in Thompson sky satellite recievers, always do a blanket change of the electrolytics using better quality components to ensure continued reliable operation.I have a meter to test capacitors. They all read 2 or 3 microfarads over what is printed on them. Don't have a scope or isolating transformer. Wouldn't know where to put a scope probe on it. Just seems a waste to dump it.
by Jeff Child
