The ATTiny sounds fantastic. I'll go with that, plus the usb programmer, and I'll grab an assortment pack of resistors and get them here asap. Oh my gosh, I forgot about the smt resistors! So tiny, I could barely solder them! But I thought there was a little trick you guys did with some double sided tape? this sounds perfect for the model though. Ultra light weight. So if I'm clear, after calculating the resistors, I then only have to learn how to program the IC from the IDE (with the code you will help me create), and then wire to the correct pins and give it a go!? I might need a little hand holding during the arduino uploading and programming.
