Thank you MrChips,
Yes, I turned off and on several times and the display works fine, but don’t show the correct characters unless I do the short circuit to the pin number 2 as I did in the video.
Is it very strange.
Could be the problem because the original LCD is 8 pin instead 7 (the new VFD)?
Also, seems that the connection is correct, the pins, everything seems OK, because if not when I do that procedure of the wire I guess I couldn’t see anything in the display right?
That wire needs to be connected somewhere perhaps?
Is it very strange.
