AlbertHall
- Joined Jun 4, 2014
- 12,346
Changes to the input signal, or input attenuator setting both affect the signal going to the trigger circuit. You will need to get used to adjusting the trigger level. 'Auto' should handle such changes better.How come w/o adjusting anything except voltage to 10mV (from 5mV to 10mV cal setup) I get scrolling signal? If I back trigging level off a bit, it stops.
