Help with Dehumidifier on switch Bypass
Freevertigo
Joined Feb 25, 2018
Hello, I am looking for for help with a dehumidifier project. I currently have a small space that is set up with a dehumidifier and a humidity controller. The controller turns on and off the dehumidifier based on a set range. The issue, however is that the dehumidifier has an on/off button so even when the controller sends 120 volts, the dehumidifier still needs someone to press the button to turn it on.
I want to bypass the on/off switch on the dehumidifier so that when it is plugged in, it immediatly turns on without having to press a button on it.
The dehumidifier is a very small unit and I have outfitted a hose so I do not have to empty the resevoir. It doesn't have any other functions other than run and shutoff if full (if the reservoir were to fill completely)
I was hoping it would be an easy fix but I suspect that the on/off switch only sends a small signal to a relay and that is out of my comfort zone without professional assistance.
Here is a picture of the dehumidifier (it is some off brand unit but it should work for the small space it runs in)
dl324
Joined Mar 30, 2015
18,524
Welcome to AAC!
You need to post a wiring diagram for the switch and a clearly focused picture of its electrical contacts.
