Help with data prediction algorithm
rutendo
Joined Sep 24, 2017
10
i am in my final year and i am doing a household power saving and i need to predict how much the user is to consume every hour based on data collected over a month hourly and stored,so my question is which algorithm is easy to implement in C programme and which source material can i use for for creating my own module for data prediction.
wayneh
Joined Sep 9, 2010
18,157
So are history and hour-of-the-day the only variables, no weather, no motion detector to see if the person is home, and so on?
There are many ways to do time-series analysis. If your prediction is merely the 30-day moving average (for that hour of the day), you could store 24 arrays, one for each hour of the day. Add daily data FIFO so that the array always contains the 30 most recent entries. Compute the average once per day once the new data arrives.
MrSoftware
Joined Oct 29, 2013
2,273
Come up with the math first, THEN write the code. Trying to come up with the math at the same time you're writing the code will be more difficult.
rutendo
Joined Sep 24, 2017
10
That's what i am asking for like the source material for algorithms that can be of use with good step by step explanations
Alec_t
Joined Sep 17, 2013
15,156
A 1 month period of data collection won't be sufficient unless the temperature of your environment is constant from one month to another. Winter usage and summer usage can be wildly different.
