Hello
I'm a new member to this great forums, and I hope I'll find some help to troubleshoot my circuit.
I want to make a light-activated circuit (it is dark-activated actually!), the comparator is connected as follows:
1- The inverting input: connected to a variable resistor to adjust the (criterion) I want to set for darkness.
2- The non-inverting input: connected to an LDR in series with a 10K resistor to detect the level of light.
The trouble is: the output of the comparator is always high, even if I adjust the variable resistor at its extremes (it has to be 12 volts) I measure the voltage at its pin in the comparator to be about 5v only and the voltage at the non-inverting input is higher than it !
I feel that the one input is affected by the other, so what's the problem ? Must I set a fixed reference voltage at the inverting input ? or should I replace the variable resistor ? or other thing should I do ?
