Help with CE Amplifier design
AHMADee00
Joined Dec 13, 2023
7
I am trying to design CE amplifier with a gain of 10. I designed the circuit in spice and it worked fine as shown.
The Voltage across Re is much greater than Vt so the gain will be approximately Rc/Re.
The problem is that when I implement the circuit in the breadboard it gives unexpected results. This is the circuit using same components values and 2n2222a bjt.
The voltage across Re is 500mV and Vce = 7V . but the gain is approximately is 0.
This is the measured output for the input signal with 7V Amplitude and 1 kHz frequency.
Does anyone know what is the problem with the circuit?
dl324
Joined Mar 30, 2015
18,471
What is the complete part number for the transistor. Technically, 2N2222A should be in a metal can. PN2222A and P2N2222A are in TO-92, but they have different pinouts.
If you swap the collector and emitter, the transistor will have very low current gain.
35,189
C1 and C2 are too large. They will create very long time constants.
Change them to 1 or 10μF.
R5 is also too large. 10kΩ is good enough.
R1 and R2 are too large. Try reducing them also.
AHMADee00
Joined Dec 13, 2023
7
It is 2N2222A-1726 as written in the package
MrAl
Joined Jun 17, 2014
13,800
For one, the transistor has to be biased harder. Lower R1 to start with.
The caps 1000uf are way too large.
1uf is fine.
The output load resistor is too large also, maybe 10k max for testing, 1k better.
dl324
Joined Mar 30, 2015
18,471
Could you post the datasheet and/or manufacturer? Every 2N2222A I've seen was in TO-18. I don't think I have any PN2222A and I don't think I've ever had a P2N2222A (didn't even know they existed until a couple years ago).
michael8
Joined Jan 11, 2015
472
Isn't that input signal a bit large? What's the output impedance of the signal source?
BobTPH
Joined Jun 5, 2013
11,656
How do you expect to get a gain of 10 with 7V input? That would be 70V output. Your amp can, at most, output 10V p-p if everything was perfect.
Also, 7V amplitude is ambiguous, it could be peak, peak-to-peak, or RMS, all of which are different.
AHMADee00
Joined Dec 13, 2023
7
It was 7v one peak. I choose this value because when the value less than 7 there will be no output signal. the circuit works as attenuator
