Help with binary counter
solidrock
Joined May 25, 2017
hi everyone please help me in this lap report
Binary Counters
Objective: Design, construct, and test a three-bit counter that countsup or down. Anenable input E determineswhether the counter is on or off.
· If E = 0, the counter is disabled and remainsat its present count eventhough clock pulses are appliedto the flip-flops.
· If E = 1, the counter is enabled and a second input, x, determines the direction of thecount.
· If x = 1, the circuit counts upward with the sequence 000, 001, 010, 011,100,101,110,111 and the count repeats.
· If x = 0, the circuit counts downward with the sequence 111,110,101,100,011,010,001,000 and the count repeats. (Do not use E to disable the Clock)
Note: Design the sequential circuit with E and x as inputs.
Submission:
Reports must include all schematics and cost of design.
Compare your results with other solutions.
Define why your design is better.
dl324
Joined Mar 30, 2015
18,476
Welcome to AAC!
Post your best effort and we'll help guide you to a solution. Are you required to use any particular type of flip flop?
We won't do homework for you.
EDIT: Edit the title of your post to be more meaningful. Introductions should be in Off-Topic.
solidrock
Joined May 25, 2017
Welcome to AAC!
thnx
i don not required any type of flip flop
WBahn
Joined Mar 31, 2012
33,255
So, as dl324 said, post your best attempt to work your homework. That gives us the necessary starting point from which to help guide you to a solution.
