Im looking for a solution to my problem. Im building a stereo system using an automotive stereo and a computer power supply. Everything is hooked up and working except for the antenna. I live deep in a valley in a mountainous area located far from any FM station, so my reception is quite weak. However I have designed an antenna with high gain and it works pretty well with my home stereo and I think it would do excellent with my latest project. The trouble Im having is the antenna plug on the rear of the head unit. Its the normal plug for a car antenna, with the center probe and the shield. I think its called a motorola plug. I have no such plug, nor do I want to spend any cash for a twist on plug, nor do I wish to open up the receiver and do any soldering. What can i substitute for this plug? A normal rca plug will fit, if I trim off some of the insulation, but I don't think it is making much contact. Anyone have any ideas what I can use? Im not above using a piece of wire and just sticking it in the hole for the plug if it will work... I guess im looking for another type plug that I can modify to use for this setup. Currently looking for an old car antenna that I can salvage the plug from,, but no luck thus far. What else could work? Any ideas?
Mods note:
Please don't upload the file with full colors as *.png, it will use too much file size as 160 Kb, you can use *.jpg and it will be smaller as 16 Kb.
Mods note:
